normal pstn circuit configuration
Mar 7th, 2007
i am using ccm4.1 with cisco3825 router for dialling out with E1 terminated in the router.
i want to go for single analog connection circuit (not BRI or E1 or T1) only 1 line.
Need help in getting the configs and voice ports required in cisco3825 router.
Thanks in advance.
Overall Rating: 5 (1 ratings)
lpezj Wed, 03/07/2007 - 01:27
  • Gold, 750 points or more
I think that you need a FXO analog voice card. Though it has two analog lines you could use one.
The code for the analog card is VIC2-2FXO. You can use too VIC2-2E/M.
Hope this helps,
Juan Luis
