setting up pix at home
Mar 7th, 2007
Hi all, If I want to put my pix on a public ip at home, do I need 3 public ip's? one for the wan interface thats goes to my provider, 1 for the inside interface of my router and 1 for the pix? or could i get away with using 2, by using ip unnumbered on the ethernet interface of my router so it uses the same ip as the wan atm interface ?
cheers
IWAN HOOGENDOORN Wed, 03/07/2007 - 05:38
  • Bronze, 100 points or more
You only need 1 Public IP address ... the Inside interface & DMZ'S are private IP ranges ...
The Private will be NATTED when going outside
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
carl_townshend Wed, 03/07/2007 - 05:50
If I only use 1 public address, that means i do all my natting on my router, I want this done on my firewall!!
