connect PIX 501 to switch
Mar 7th, 2007
I'm connecting the PIX 501 between my Cisco uBR900 cable modem/router and a 3Com OfficeConnect switch. This will replace a 3Com firewall. The switch is currently connected to the LAN port on the 3Com firewall. Do I simply connect the switch to any of the 4 PIX 501 ports? Does it make any difference which?
ROBERTO TACCON Wed, 03/07/2007 - 05:23
you can coonect the switch to any port; check the duplex and the speed of the interface of the 3COM switch vs the inside interface of the PIX 501
# sh ver
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
Compiled on Thu 04-Aug-05 21:40 by morlee
Pix up 29 mins 13 secs
Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 0016.9ddb.49a5, irq 9
1: ethernet1: address is 0016.9ddb.49a8, irq 10
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
Roberto
suschoud Wed, 03/07/2007 - 06:11
  • Gold, 750 points or more
the inside interface of pix is a 4-port switch.so,you can connect the 3com switch to any of the port on pix's inside interface.
as specified above,make sure that the speed and duplex settings are same on both,the pix and connected switch.
you can check the status of interface on firewall by issuing the command " sh interface ".
the interface and line protocol should be ip.
for the normal internet access:
nat (inside) 1 0 0
global (outside) 1 interface
route outside 0 0
hope this helps!!
Sushil
Cisco TAC.
