changing ref bw under ospf
Mar 7th, 2007
Hi All,
Does setting the reference bandwidth under ospf require ospf process to be reset?
I don't think it does and plan to run a quick test.... Just wondered if anyone knew as well?
thanks very much,
royalblues Wed, 03/07/2007 - 05:18
I think it does.
But make sure you have this setting on all the routers running OSPF in your domain.
HTH, rate if it does
Narayan
