03-07-2007 05:01 AM - edited 07-03-2021 01:44 PM
I have a 2811 with a WLC6 installed. I have logout of the CLI and I am stuck in the user login page. How do I get back to the Routers CLI with out rebooting the whole router
Solved! Go to Solution.
03-19-2007 07:11 AM
the last post was right in that you press ctrl
You then enter disconect to stop your session returning to the WLCM when you press return on an empty command line.
03-13-2007 06:43 AM
To get back to the ISR, press CTRL+SHIFT+6 and X. This will take you back to the WLC CLI. When you press enter twice, you will come back to the WLC CLI.
03-14-2007 05:44 AM
just get the User:
prompt. any other ideas?
03-19-2007 07:11 AM
