Nat translation
Mar 7th, 2007
How do I set my pix 525 nat translation to hide internal IP addresses to the maximum extent possible. I need to configure the NAT firewall so that outbound traffic appears as if the traffic had originated at the firewall.
Kamal Malhotra Wed, 03/07/2007 - 06:12
  • Cisco Employee,
You need omething like :
nat (inside) 1 0 0
global (outside) 1 interface
HTH,
Please rate if it helps,
Kamal
lavong3600 Wed, 03/07/2007 - 06:27
What is HTH
Should the global outside point to the router?
acomiskey Wed, 03/07/2007 - 06:31
  • Green, 3000 points or more
Not sure what you're asking there, but the above commands mean that everyone one the inside will be translated to the outside address of the pix.
Kamal Malhotra Wed, 03/07/2007 - 06:51
  • Cisco Employee,
HTH is Hope That Helps. :-)
If the interface names are the 'inside' and 'outside' then you just go ahead and paste the commands sent to you earlier. Global outside is not a route command so it does not point to any other device. This means the traffic that needs to get NATed/PATed will be NATed/PATed to the outside interface of the PIX.
Hope That Helps,
Kamal
