fw_qs_filled error
Answered Question
Mar 7th, 2007
Hi!!
Do you know the meaning of "fw_qs_filled" error counter on "show crypto engine accelerator statistics" command?!
Cinzia
Correct Answer by Kamal Malhotra about 10 years 3 months ago
Hi Cinzia,
Are these counters increasing or these are at 0? I have not yet tried to find a meaning to these counters.
Kamal
Overall Rating: 4 (1 ratings)
Correct Answer
Kamal Malhotra Wed, 03/07/2007 - 06:42
  • Cisco Employee,
Hi Cinzia,
Kamal
csiracusa Wed, 03/07/2007 - 06:45
Hi Kmalhotr,
the counters are increasing....
Cinzia
Kamal Malhotra Wed, 03/07/2007 - 07:06
  • Cisco Employee,
Hi Cinzia,
You seem to be hitting a bug. Which says "
"Symptoms: Small packets may be dropped when CEF is enabled. This situation may cause encryption or description failures for packets with a certain packet size.
Conditions: This symptom is observed when packets are switched on any interface via CEF or fast switching. The symptom affects packets with a small size (for example, 36 or 37 bytes).
Workaround: There is no workaround."
There is a duplicate bug of this one that is titled : VPN-NetGx: Excessive CPU usage with AH & multilink group
and it says "Using AH (authentication header) with ppp multilink-group uses excessive CPU. This happens only on the decrypt side. Two serial interfaces are bundled together on a "Multilink interface". On decryption Router A's CPU reaches 95% with just 100pps of 64 bytes and Router B's CPU reaches 95% with just 190ppps. Same routers, if used for
encryption with the same traffic do not use more than 5% of their CPU.
Even sofware crypto can decrypt the same amount of traffic with less than
5% of CPU.
This happens only with AH-SHA-HMAC or AH-MD5-HMAC and does not happen with:
ESP-3DES
ESP-3DES ESP-SHA-HMAC
ESP-3DES ESP-MD5-HMAC
ESP-AES
ESP-AES ESP-SHA-HMAC
ESP-AES ESP-MD5-HMAC
If we increase the rate, packets are dropped on the decrypt side. "fw_qs_filled" counters in "show crypto engine accelerator stat" will
start increasing and eventually traffic will stop. "
In this situation, I would recommend opening a TAC case for troubleshooting.
HTH,
Please do rate if it helps,
Kamal
csiracusa Wed, 03/07/2007 - 08:10
Thanks a lot Kamal!!
If this counter will increase again I will open a TAC Case.
Best Regards and have a good time!!!
Cinzia
