pl help: EAP-TTLS configuration
Mar 7th, 2007
hi,
if any one had implemented EAP-TTLS as secuirty between clients and wireless devices, then pl help me in configring. And what are the security devices required
Srihari
Overall Rating: 4.3 (3 ratings)
sbarasiscom Wed, 07/11/2007 - 07:29
I did this but deos not work,
Does any one have further documents,
Premdeep Banga Wed, 07/11/2007 - 17:00
  • Gold, 750 points or more
Do you want to configure EAP-TLS or EAP-TTLS?
Both are different.
If EAP-TLS, then what is the radius server, and have you configured client certificates on clients?
What is the error logs do you get on Authentication server?
That will give you right direction.
Prem
srihari_rgda Wed, 07/11/2007 - 22:19
Thanks for giving a response,
I want to configure EAP-TTLS, and i have radius server as Cisco ACS. If you have any procedural document for configuring EAP-TTLS, could you please share.
Srihari
Premdeep Banga Thu, 07/12/2007 - 04:34
That?s what I suspected.
Unfortunately Cisco ACS doesnot support EAP-TTLS
These are the protocol supported,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/user/overvw.htm#wp849719
-EAP-MD5
-EAP-TLS
-LEAP
-PEAP
-EAP-FAST
Also check,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/user/overvw.htm#wp857274
http://en.wikipedia.org/wiki/Extensible_Authentication_Protocol
What I can suggest you is go for protocol similar to EAP-TTLS i.e. PEAP
PEAP Configuration:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a0080545a29.shtml
Prem
srihari_rgda Thu, 07/12/2007 - 04:53
Dear Prem,
We had allready implemented PEAP but we have a new requirement that we have to install EAP-TTLS.
what is hte next alternative for this solution and EAP -TTLS is more secured then EAP-TLS (PEAP).
srihari
Trending Topics - Security & Network
