CallManager OS Media
Answered Question
Mar 7th, 2007
Is it possible to replace a lost CCM OS CD? I looked at cisco.com/upgrade, but I wanted to ensure that I get the OS CD and not just the application. More importantly, the server that we need to install CCM on is an IBM server; however, all of our SAU contracts are currently on HP servers.
Please let me know what my options are.
Thank you,
Ohamien
Correct Answer by Rob Huffman about 9 years 10 months ago
Hi Ohamien,
Yes, I think that part number should work. We ordered a CCM 4.1.3 Upgrade package not too long ago that came with OS 2000.2.7 (SET) and OS 2000.4.1
Hope this helps!
Rob
Overall Rating: 4.7 (3 ratings)
ouhakheme Wed, 03/07/2007 - 07:51
I guess with SASU they should support the software no matter what contract I have on my hardware. I just don't want to get into a situation where they will only send me the disc for the HP servers that are covered under SNT, I have the HP Media.
Rob Huffman Wed, 03/07/2007 - 07:50
Hi Ohamien,
Just to add to Sankars always great info, if you go through the Upgrade path you should get the full CD set;
Q. What do I need to do if I have lost my CDs or need another set?
A. Refer the customer to the Product Upgrade Tool (PUT) ( registered customers only) .
The customer is required to enter their Cisco Software Application Support Plus Upgrades (SASU) contract number and request the CD/CD set.
AVVID CD Software Request Cases FAQ
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
Hope this helps!
Rob
ouhakheme Wed, 03/07/2007 - 08:04
Which item should I order? Will CM4.1-K9-UPG= get me the OS CDs for 4.1, without upgrading?
Correct Answer
Rob Huffman Wed, 03/07/2007 - 09:27
Hi Ohamien,
Hope this helps!
Rob
Rob Huffman Wed, 03/07/2007 - 10:24
Hi Ohamien,
You are most welcome! Thanks for your kind words :)
Take care,
Rob
