CISCO 1841 Configuration
yytellmey Wed, 03/07/2007 - 08:45
What WIC is it? 1841 supports only a few modules of WIC cars.
hi please help me in configuring a Cisco 1841 router with ILL.
This will be PPP connection and fo/0 of router will be connected to the firewall while the serial port will be terminating at ISP Modem.
I think this is simple PPP at serial port but i am still not clear on the Ethernet Port connected to Firewall.
Please help.
spremkumar Thu, 03/08/2007 - 22:30
Hi Omeshwar
You just need to key in the ip adress provided by the SP to which you are getting connected..
interface serial 0/0
ip address x.x.x.x y.y.y.252
encapsulation ppp
About configuring your local lan totally depends on the ip addressing block being assigned by your SP.
If you are getting a public ip block for your local lan you can configure up the same onto your ethernet port which connects to your PIX firewall may be via a switch or through a cross cable..
