STP/Trunking on CE500G-12TC
Mar 7th, 2007
How do I disable 801.2Q trunking on WS-CE500G-12TC ports to other inexpensive non-Cisco unmanaged level-2 switches. My new Express 500 worked fine for a while, then said that STP blocks those ports when the communication went out. I however had configured them with disabled STP, but enabled IGMP snooping.
Thank you for any hints you?d give me.
Overall Rating: 5 (1 ratings)
qnguyenlhm Wed, 03/07/2007 - 11:14
Thank you, Amit. I've really appreciated your prompt reply. I'd guess that all my Cisco goodies (STP, Trunking, EtherChannels, etc.) are not applicable for those unmanaged Switches ?
qnguyenlhm Thu, 03/08/2007 - 06:33
Hi Amit,
Unmanaged level-2 switches now configured as "other role" work, but not that fast as before when configured as "switch". Do you have any further suggestions, other than buying additional models 500-24TT for the distribution layer ?
Quoc
