DND issue with CME 4.0 and a 7940 Phone
Mar 7th, 2007
I keep having a reoccurring problem with my CME and a 7940 phone. The phone keeps going into DND mode and will not allow anyone to use it. When DND is enabled we cannot remove it. There is no way to get it out of DND on the phone. The only way we can fix it is by deleting the ephone and add it again.
The weird thing is I only have one template on this router.
ephone-template 1
softkeys idle Redial Newcall Cfwdall Pickup
softkeys seized Redial Endcall Cfwdall Pickup
softkeys alerting Callback Endcall
softkeys connected Hold Confrn Trnsfer Park
The phone has two ext assigned to it. The main one and then a ? Sales ext ?, this is basicly 6 exts in a hunt group.
ephone-dn 22
number 1022
pickup-group 2
description Floor-2
name Floor, Two
call-forward all 1061
call-forward max-length 4
corlist incoming CSS-Local
hold-alert 60 originator
ephone 5
ephone-template 1
username "Front-2" password null
mac-address 0015.6316.E1DD
paging-dn 7
type 7940
button 1o12,16,17,18,19 2:42
Can anyone shed some light on why this keeps happening?
charles.breaud Fri, 03/09/2007 - 10:25
We had the same issue, it's not just happening but your users are hitting the DND button in ringing mode. Your softkeys need "softkeys Ringing answering" added to the bottom of your list. If you don't have the softkey answering you have an older verision of the IOS and you need to cut on FAC codes and then just tell the user to pickup the phone and dial **7 and it will take the phone off DND.
Hope that helps
