Backend SSL Configuration
yycsandman007
I am having some issues configuring backend SSL stuff on CSS11500. I found the following doc on the Cisco website, and tried to substitute my servers and addresses in, but am getting some errors.
Couple of questions about the config:
where the backend-server commands start, why are ports 81 and 8003 referenced? I am wanting to use 443. Same with the service backendX commands...they reference port 8003. The server farm behind the CSS is only listening on 443. I tried to substitute 443 in for 8003, and then the CSS gives me an error "%% Backend-server ip/server address and port values must form unique tuples."
After searching for the meaning of this error, I am still confused.
thanks in advance!
Also, I have the front end SSL working, and the CSS is providing the cert. As soon as I accept the cert, the browser session hangs.
The template/guide I am using is at :
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a0080220dab.shtml
Your config looks ok. You need to run sniffer on both backend server and client.
We need to know whether CSS is initiating conn to backend server or not.If it is then what happens to return traffic.
10 Replies 10
The flow in the example is as follows
1. Client hits Content rule "front" on port 443 (1010.66.86.28:443 )"
2. CSS chooses "service ssl_front" for this rquest.
3. Service ssl_front uses SSL module to decrypt the request
4. request is decrypted and destination ip is changed to "10.1.1.10" & dest port is changed to "81"
5. Return traffic from SSL module hits CSS again on 10.1.1.10:81.
6. This traffic hits content rule "back" which selects either of 3 services (backend1,backend2,backend3)
7. These three services initiate a ssl session to backend ssl servers listening on port 8003.
In the guide port 81 is used as a place holder for decrypted traffic from SSL module and port 8003 is the ssl port of backend servers.
When You are usnig SSL backend, netwrok tuple between
'backend-server <> ip address'
'backend-server <> port'
'backend-server <> server-ip'
'backend-server <> server-port'
must be unique. Error you are facing suggests that you are not maintaining uniqeness among them.
Syed Iftekhar Ahmed
Thanks....that definitely helps....so can my backend servers NOT use port 443 to receive client requests? Is that what I need to have changed to make this work? If the backend servers are set to listen only on 8003 will that solve my issue? I understand the port 81 issue now.
thanks again!
You can definitely have backend SSL servers running on port 443
the details of network tuple I mentioned is as follows
is the Virtual address for the backend server, It should correspond to service address
is the virtual port of Backend server (default 80). Virtual port directs clear text data
from SSL Module to CSS.
is the real IP address of the Backend SSL server.
is the SSL port on which Backend SSL server is listening.
If you do not enter this command it will be set automatically to 443.
Syed iftekhar Ahmed
This is starting to make more sense, but I am still having issues. I changed the config to where I thought it would work, but still won't. I have attached the output from the device for "play script showtech"
any assistance you are able to provide would be greatly appreciated!
Thanks again for your help. I think I'm almost there!
You are still using same ips for
arrrrgh!! In the example, for backend-server 20 , the ip address and server ip address are the same though....
please advise
thanks
My bad..
Since we are spoofing the server on port 81 we can use same IPs.
Are you still getting the error you mentioned earlier?
nope...not the tuple error any more...it just doesnt work....when I point my browser to the outside vip address (.13), the css intercepts the request and terminates the session. I know this because when I get the cert warning, if I look at the cert, it is the one on the CSS. After that point, the browser just pukes and doesn't make it to the back end servers. If I https directly to the real ip of the backend server, or the vip (.8) it works fine and the server is providing the cert. It is something specifically to do with the backend servers. Can't reach them thru the front end vip (.13)
Any thoughts or comments? you still have the config right? I posted it in one of the previous messages.
Dazed and Confused
thanks again for the help. these discussion groups are very helpful.
Sandeep
I got it!!!! I ran ethereal on the server and captured traffic. I noticed that there were a ton of https resets, as well as certificate errors. I changed the following lines in the config and it works perfect now.
backend-server 10 cipher rsa-export-with-rc4-40-mds
backend-server 20 cipher rsa-export-with-rc4-40-mds
CHANGED TO
backend-server 10 cipher rsa-with-rc4-128-mds
backend-server 20 cipher rsa-with-rc4-128-mds
I also had to add advanced-balance sticky-srcip for the app to work properly
Thanks very much for your assistance!
Sandeep
