Webview DST Upgrade
Mar 7th, 2007
Has anyone done the recommended Webview DST changes for IPCC Enterprise 6.0? The Field Notice states to upgrade to j2sdk1.3.1 version 19 or higher or run the tzeditor for 1.3.1. I can't find either on the Sun Java Downloads page.
thomas1 Mon, 03/12/2007 - 13:42
The link is below:
http://java.sun.com/javase/downloads/index.jsp
I had to register to actually get the zip file. We are using ICM 7.0, but I think this update tool works for the 1.3.1 JRE according to the read me file. I rebooted the Webview server after doing the update and it worked fine with no problems.
