CCNP/CCIP Lab Hardware
Mar 7th, 2007
I am looking at building a home lab to help with my CCNP and CCIP cert. I was hoping to get some opinions about this equipment line-up.
6 - Cisco 3640 Routers, 128/32 RAM, 12.4 Advanced Enterprise IOS
6 - NM-4A/S 4 Port Serial Modules
12 - Cisco NM-1E2W Modules (1 per 3620, 2 per 3640)
1 - Cisco 2511 - 2 Serial, 1 Ethernet, 16x Asynchronous Ports (Terminal
Server)
1 - Cisco 2522 Router, 10 Serial Ports, 1 Ethernet Port, 1 ISDN Port
2 - Cisco 2924 Switches
10- Ethernet Cables
10- DCE/DTE Crossover Cables
10- AC Power Cords
1- Console cable kit
2- Octal Cable for 2511
Any comments are welcome.
devang_etcom Wed, 03/07/2007 - 14:21
  • Gold, 750 points or more
add one more switch of 3560... and you will have perfect lab for NP/IP and also you can go for some of the CCIE...
how much did it cost you???
regards
Devang
devang_etcom Wed, 03/07/2007 - 17:14
hey all of the equipments you listed above cost you $3000...
devang_etcom Wed, 03/07/2007 - 18:55
can i have the contact detail of you as well as that vendor because i am also planning to get some router but its of 26XX series?
looking for needful reply...
regards
Devang
