2811 vwic-2mft-t1 for 2 remote sites
this is have a preliminary config on a cisco 2811 with one t1 wic on slot 0
and a vwic-2mft-t1 on slot 1.
i want to split slot 1 interface to
2 resite I a ordered 2 PPP circuits.
The one site on s0/0/0 we are installing an Avaya 350 gateway.
is the config for the vwic-2mft-t1 correct?
ersion 12.4
hostname RTR-001
boot-start-marker
boot-end-marker
card type t1 0 1
no logging buffered
enable secret 5
no aaa new-model
resource policy
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no network-clock-participate wic 1
ip subnet-zero
ip cef
ip domain name domain.local
ip name-server 10.1.0.10
ip name-server 10.5.0.5
username XXX privilege 15 secret 5
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 24
controller T1 0/1/1
framing esf
linecode b8zs
class-map match-any AvayaControl
match ip dscp ef
class-map match-any AvayaVoice
match ip dscp ef
policy-map xxx-Avaya
class AvayaVoice
priority 280
class class-default
fair-queue
random-detect dscp-based
interface FastEthernet0/0
ip address 10.1.0.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.5.0.46 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
description PPP to xxx
ip address 65.x.x.x.255.255.252
encapsulation ppp
interface Serial0/1/0:0
ip address 65.x.x.1 255.255.255.252
encapsulation ppp
interface Serial0/1/1:0
ip address 65.1.15.1 255.255.255.252
encapsulation ppp
router eigrp 100
network 10.0.0.0
no auto-summary
ip classless
ip route 10.1.11.254 255.255.255.255 Serial0/0/0 permanent
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
transport output none
scheduler allocate 20000 1000
end
Thanks for your help
jhimye Fri, 03/09/2007 - 13:15
In the controller config, unless you really want to use only timeslot 24, change it to
channel-group 0 timeslots 1-24
I've seen that mistake before.
Jhimye
