Brandon Buffin Wed, 03/07/2007 - 19:48
  • Purple, 4500 points or more
The configuration varies by switch. See below for variations.
Cat 4k/6k
set vlan 10 5/1
set port auxiliaryvlan 5/1 11
Catalyst 3500 and Etherswitch module
switchport mode trunk
switchport trunk native vlan 10
switchport voice vlan 11
Catalyst 3550/3560
switchport access vlan 10
Hope this helps. If so, please rate the post.
Brandon
carl_townshend Thu, 03/08/2007 - 01:15
Hi There, thanks for that, what if I have say 4 different data vlans on the same switch for each dept for example? what would i do here as they all cant be native ?
Brandon Buffin Thu, 03/08/2007 - 05:27
This is a per port configuration, so 1 vlan will be native on each port.
On a trunk port, you can set the vlans that are allowed with the following command.
switchport trunk allowed vlan
If you ? after this command, you will see that you have several options for allowing vlans.
Hope this helps.
Brandon
carl_townshend Thu, 03/08/2007 - 05:39
So could I on my port have say
switchport access vlan 50
switchport voice vlan 10
