Trying to update device package for CiscoView 6.1
Mar 7th, 2007
I am trying to update the device package for CiscoView 6.1 to include the C6506-E chassis and Sup 720 and Sup 32 along with the 6548 and 6748 modules but I keep running into this error.
For Product(s) : cvw
Install Invoked by user : gladney
The Package(s) Selected for Install :
Cat6000
WARNING : Cat6000(9.0):major versions are incompatible.Required version 9.0 for Cat6000 package
Installation Completed for : cvw
I'm not sure what verison it's incompatable with? Does this mean I have to manually deinstall v6.0?
Gary
Joe Clarke Wed, 03/07/2007 - 16:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This most likely indicates that one of the dependencies of this package are not met. The easiest way to update CiscoView packages is through the Common Services Software Center in the CiscoWorks GUI. From there, you can select all available CiscoView packages, and choose to update them all (thus eliminating this problem). However, the psu.log should point to the exact problem package here.
ggladney Wed, 03/07/2007 - 19:29
What I posted in the message was the error reported using the GUI. I also tried the PSUCli.sh with same results. I will take a look at the log file. I was able to update and add some device packages for the 3750 and 2970 but not the 6000.
Gary
Joe Clarke Wed, 03/07/2007 - 21:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
When you did the update in the GUI, did you select ALL available package updates, or just the ones corresponding to the devices you wanted? There are ancillary packages that are required as well.
ggladney Thu, 03/08/2007 - 07:16
Can you tell where the psu.log lives. I looked all through the /opt/CSCOpx directory structure and can not find it. I also looked /tmp.
Gary
Joe Clarke Thu, 03/08/2007 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
/var/adm/CSCOpx/log/psu.log on Solaris.
