CNR with VMWARE or Virtual Server
Mar 7th, 2007
Can i operate CNR with VMWARE or with virtual server?
aghaznavi Tue, 03/13/2007 - 06:58
It's not supported. For your information I am sending you some information about the minimum requirement for CNR
CPU architecture
Intel Pentium III or equivalent
Sun Netra AC200
Intel Pentium III or its equivalent
OS version
Windows 2003 or Windows 2000 (Service Pack 2 or later is recommended)
Solaris 8 or Solaris 9
Red Hat Linux Enterprise Server (ES) 3.0, or ES or WS 2.1 (kernel
2.4.9-e.24), or 7.3 (kernel 2.4). Use RPM Package Manager (RPM) 4.0.4
or later.
512 MB on all platforms
Disk space
18 GB recommended, minimum 310 MB required for installation
Swap space
100 MB free swap space
is Wed, 03/14/2007 - 14:29
We understand the minimum requirements.
Only to clarify, we have a very robust equipment that hosts different virtual machines acting as server for different applications. Every Virtual machine has its own resources and even they don?t know that they are "living" as virtual machines and sharing resources with others.
If we installed CNR as another Windows 2003 server virtual machine, all the minimum requirements will be met.
What is the reason that avoid the support to CNR if we use this scheme ?
What kind of support you are not giving us if we used this scheme?
What problems could we face if we implement this scheme?
Thanks and best regards.
