Amit Singh Wed, 03/07/2007 - 20:51
  • Cisco Employee,
You can use " show interface serial x/y" and check the input/ output packet rate. This will give you an idea of how much the bandwidth is used in RX and TX. The output is an average of 5 minutes interval. If you want to change the interval to take some more granular readings, chnage the interval like :
conf t
int serial x/y
load-interval 30--> seconds
HTH,
-amit singh
bvsivaprasad Thu, 03/08/2007 - 00:16
Hi ,
i want exact current bandwidth to measure at that second through serial interface,any command is there.
spremkumar Thu, 03/08/2007 - 22:31
  • Red, 2250 points or more
Hi Siva
I feel you can also try out some NMS solution which can provide you the utilisation part..
Lots of freewares available in net which you can download and configure it accordingly..
regds
