Add 1 more tunnel on the existing firewall
Mar 8th, 2007
I have an existing tunnel between 2 sites: (A and B) configured on 2 FWs. Now I was asked to add 1 more tunnel berween A and C. Since C is new site, I can just copy the existing configuration and change the IP address for site C, how about A? how is the configuration need to be done to add one more tunnel?
The following is my existing config on FW A (only VPN related commands are listed):
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list NoNAT permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
nat (inside) 0 access-list NoNAT
isakmp enable outside
isakmp key xxxxxxxx address 1.1.1.1 netmask 255.255.255.255
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 1 ipsec-isakmp
crypto map outside_map 1 match address 101
crypto map outside_map 1 set peer 1.1.1.1
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
management-access inside
sysopt connection permit-ipsec
by the way: A site LAN is 192.168.1.0
B site: 192.168.2.0
C site: 192.168.3.0
kaachary Thu, 03/08/2007 - 01:20
  • Cisco Employee,
Assuming you are using same encryption and authentication parameters as Site B (Same Iskamp policies and same Trnasform set), you require following changes to add a tunnel between Site A and C.
access-list 102 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list NoNAT permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
isakmp key xxxxxxxx address netmask 255.255.255.255
crypto map outside_map 2 ipsec-isakmp
crypto map outside_map 2 match address 102
crypto map outside_map 2 set peer
crypto map outside_map 2 set transform-set ESP-3DES-MD5
That's it !!
*Please rate if this helps.
-Kanishka
shibindong Thu, 03/08/2007 - 01:24
thanks for your prompt reply, my another question is "2" in the "crypto map outside_map". correct me if i am wrong, "2" in the IPsec should the same as the number in ike configure, right?
kaachary Thu, 03/08/2007 - 01:28
  • Cisco Employee,
No, it doesn't matter.
It could be any number other than "1" as you have one crypto map defined with priority "1".
All the crypto maps on the device, should have the same name, but different sequence number. The sequence number can be random.
It has nothing to do with the IKE policy.
*Please rate if helped.
-Kanishka
