How to get cummulative MS patches for 2006/2007 for Unity?
Mar 8th, 2007
I found Unity recommended 30+ MS patches for Unity. My last patches was at the beginning of 2005 and have a big gap to keep the Unity up to speed on MS patches. I was told to download each patch i.e. ms06-22 918439 and load one at a time. Is there a fast way to get all patches for year 2006 & 2005?
Thus, I can apply in one goal instead of 30+ times. Does the Cisco owned patches included MS patches. I am running Unity 4.0 Win 2000 sp4. Au Ray
Tommer Catlin Thu, 03/08/2007 - 10:24
There is not a "rollup" service pack installer like in Callmanager. CCM will install all the patches in one large bulk. Unity, sad to say.. one at a time. But I know you can, if you are a good scripter, "tie" the patch installs together to have them install all at once in a batch.
Tommer Catlin Fri, 03/09/2007 - 07:32
You will have to check with your local Cisco SE or contact TAC for more information. We all hope they can supply a "rollup" pack once a month because it does take a lot of time.
good luck!
