Preix incoming calls on MGCP gateway
Mar 8th, 2007
Hi all,
I have an issue as i have seen on this forum many times before regarding prexing incoming calls. I know that there is a way on H323 gateways and a way on MGCP using translations BUT..... when you add the mask for the translation it will not catch all numbers for example many countries have a different amount of digits on their numbers so they system will not match that in the mask and add either a ? or cut the digits it cant match.
Has anyone else experienced this issue and solved it?
Any help would be gratefully received.
lfulgenzi Thu, 03/08/2007 - 04:44
  • Silver, 250 points or more
Which gateways are you using? What system are you using - CallManager or CME?
edward.shanley Thu, 03/08/2007 - 05:51
i'm currently using 3725, MGCP and CCM. I looked on tac case collection and they know its and issue but do not have a date for a fix
