Extended ACL Problem
Mar 8th, 2007
Here is my Extended ACL. I use this access-list under my ethernet 0/0 as a in. My problem is that;
I want to permit all users to use smtp,pop3,rdp... services. And only IP Number's that are in list can use www,ftp...services. These services ports between 1-120 tcp and udp. But strangly only written IP address can be use smtp and pop3 services. Normal users take an send and receive error from Outlook. What can I do? Thank you.
csco10387876 Thu, 03/08/2007 - 06:18
Can you try to add an explicit deny with log at the end of your ACL so you can see what is drop exactly ?
Luc
