03-08-2007 03:57 AM - edited 07-03-2021 01:45 PM
Dear
this error happened when the client try to connect
some clients coneccted then disconnected the other client couldnt connect please check the attached files
please advice wht is the main problem and how can i fix it
thanks in advanc
Solved! Go to Solution.
03-08-2007 04:04 AM
This error happens due to client or accesspoint sending requests too fast. Try the following :-
1. Under System Configuration->Global Authentication enable "Fast Reconnect"
2. Under Global Authentication enable "AP EAP Timeout" and set the value to 20-30.
3. On the Client set the radius-server timeout to 15-30
This also happens due to a bug in MS Windows XP SP2. The bug can be found at :-
http://support.microsoft.com/kb/885453/en-us
Vivek
03-08-2007 04:04 AM
Vivek
