WebVPN failure
Mar 8th, 2007
I have set up WebVPN on an ASA, and it seems almost to work, it comes with one error though, that i can not seem to find any information about.
webvpn_auth.c:webvpn_aaa_callback[3514]
WebVPN: AAA status = (ACCEPT)
webvpn_portal.c:ewaFormSubmit_webvpn_login[1632]
webvpn_auth.c:http_webvpn_post_authentication[1153]
WebVPN: user: (netteam) authenticated.
webvpn_auth.c:http_webvpn_auth_accept[2164]
eek: no tunnel protocol!
webvpn_portal.c:ewaFormServe_webvpn_login[1564]
webvpn_portal.c:http_webvpn_kill_cookie[387]
webvpn_auth.c:webvpn_auth[341]
WebVPN: no cookie present!!
its the line starting with eek:, i have a similar setup on another ASA configured almost same (different ip's etc), but this one i can not seem to get to work.
Please Advice
Lars Christian Andersen
Kamal Malhotra Thu, 03/08/2007 - 11:29
  • Cisco Employee,
Hi Lars,
You probably don't have the WebVPN protocol configured in the specific group policy or the DfltGrpPolicy. Try configuring it and you should not see this message any longer.
For configuring it, goto the
group-policy DfltGrpPolicy attributes
and issue the following command
vpn-tunnel-protocol webvpn
Hope this helps,
*Please rate if it helps,
Kamal
lcandersen Fri, 03/09/2007 - 02:05
Hi Kamal,
I have the
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
under the group-policy DfltGrpPolicy attributes, that is why i do not understand that output, if you need more of my configuration listed please let me know what parts you need.
