3005 upgrade for DST
Answered Question
Mar 8th, 2007
I was looking at the released code for a VPN 3005 to accomodate the new DST change and see there are 2 releases - 4.1.7.Q and 4.7.2.K - what (if any) are the differences and when would I choose one over the other?
Correct Answer by Kamal Malhotra about 10 years 2 months ago
Hi Tim,
Both are different releases. I am forwarding you the release notes for the 4.1.7 F and 4.7.2
4.1.7 F :
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/417fcn3k.htm
4.7.2 :
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_7/472con3k.htm
You should be able to find the primary differences. E.g. SSL VPN client and Secure Desktop is only supported in 4.7.x code series.
HTH,
Please rate if it helps,
Kamal
Overall Rating: 5 (1 ratings)
Correct Answer
Kamal Malhotra Thu, 03/08/2007 - 06:29
  • Cisco Employee,
Hi Tim,
4.1.7 F :
4.7.2 :
HTH,
Kamal
