2 CCM servers integration w/Unity 4.0.5, one rejects phone's registration
Mar 8th, 2007
Hi there,
I need to integrate 2 CCM servers (CCM4.1(3) and CCM 3.3(5)) w/ 1 Unity 4.0.5.
CCM4.1(3) w/Unity4.0.5 done, works properly.
CCM 3.3(5) integration successfully. (I use Unity->manage integration-> ...
Call Manager cluster2->
verify server, successfully.)
Problem is,
that when I tried to add a phone to CCM 3.3(5) for testing,
this callmanager server rejects the phone's registration.
Is it doing with the configuration between two CallManager servers?
background:
Call Manager cluster1: CCM 4.1(3)
Call Manager cluster2: CCM 3.3(5) is new added server.
appreciate your reply.
Brandon Buffin Thu, 03/08/2007 - 07:48
  • Purple, 4500 points or more
Are you using auto-registration or manually adding the phones? If auto-registration, make sure that auto-registration is enabled for the server under System -> Callmanager in CCM admin.
Hope this helps.
Brandon
master001 Tue, 03/13/2007 - 21:35
sorry for late reply.
I am not using auto-registration. already disabled.
Checked DHCP server. That causes the issue.
The IP phone receives IP addr. from CCM4.1(3)'s DHCP server--switch.Therefore,CCM3.3(5) rejects its registration.
Should I put CCM2 into another VLAN, and then doing InterVLAN on switch?
Or anybody got better idea? and how?
Thanks.
