Database replication errors - between two appliance 113
Mar 8th, 2007
I have two Secure ACS appliances - primary and a secondary. The secondary is behind the firewall and so we have the IP addresses nat'ed. I can get to the sec appliance via the natt'ed Ip address, but it the primary server says he does not see it. below is the error message I am getting
Inbound database replication from ACS 'Primary' denied - shared secret mismatch
i did read thru the earlier conversation, but It does not solve the issues I am haivng with the replication.
Pls help.
Vivek Santuka Thu, 03/08/2007 - 08:10
Usually "shared secret" mismatch means the primary's self key and the primary's key on secondary server do not match.
I would like to to point out that replication is not supported with NAT.
Vivek
wordworship Thu, 03/08/2007 - 08:53
its worked before. the keys do match.
below is the link that the TAC engineer sent to me:
Vivek Santuka Fri, 03/09/2007 - 05:14
No link in the above post.
Bust if you are using ACS 4 then please check the keys of the NDG and try moving the AAA Server entry to a different NDG.
Vivek
wordworship Fri, 03/09/2007 - 10:41
Vivek,
Thanks for yor response.
Oops. Sorry about that. below is the link I was give:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080742f60.shtml#configure_db_nat
I am currently running CiscoSecure ACS v3.3 on the Appliance.
Also is the line from the log of a successful replication: Nothing has changed since then.
Inbound database replication from ACS 'notacs01' completed
Vivek Santuka Sat, 03/10/2007 - 05:51
We need to look at Auth.log for events around the replication.
As I said before, you should try re-entering the secre keys again before looking at logs.
Vivek
