how to configure e1 in a lab enviroment
Mar 8th, 2007
hello all
i have a query regarding configuring E1 on cisco 2811 that how can i configure E1 for the lab enviroment.using two c2811 routers with VWIC-2MFT-703.i want to connect them back to back.what the cabling scheme should i
adopt.and what would be the base confiurations.So the controller would be in an UP early help would be highly appreciated.
spremkumar Thu, 03/08/2007 - 22:26
Hi Kamran
AFAIK you get the signals on 1,2 & 4,5 pairs.
Keep normal 1,2 & 4,5 on one side and just try to reverse the same on the other side and check out ..
