Cisco 851W
Mar 8th, 2007
Hello does anyone have experience with the Cisco 851W and it's wireless configuration. I am having tuff time allowing my laptop to connect to device. I don't see any place for a simple wep key or mac address. Any help would be so great, thanks - Chuck
ArdjanCisco Thu, 03/08/2007 - 10:33
My config on my 871w:
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers tkip
ssid myssid
vlan 10
authentication open
authentication key-management wpa
wpa-psk ascii 7
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
chuckbaur Thu, 03/08/2007 - 11:06
Has anyone used the SDM wireless interface to configure the wireless portion? I've configured the WPA and I get prompted for a key but it never resolves/connects. I am really lost here any more help would so great. Thanks in advance - Chuck
tu_amor66 Tue, 08/14/2007 - 10:29
Ones you configure the wireless to bridge. Configure the wireless from the wireless config tab in SDM.. It's easier edit the connection in wireless security menu.
