aspringman Wed, 03/28/2007 - 13:32
How is this coming along? Do you expect to have a compliant version this month end? If not, can you give me a tenative date?
aspringman Wed, 04/04/2007 - 04:45
When I clicked on the link you provided, the download page says, There are currently no files for this type.
What is the best way for me to get this new client?
ggilbert Mon, 04/09/2007 - 10:48
Are you still having problems to get the new client.
See the downloads section on CCO and get to the VPN client. you will see the Vista client.
Gilbert
aspringman Tue, 04/10/2007 - 10:01
Can you please give me the URL for CCO? I'm not familiar with this.
aspringman Wed, 04/11/2007 - 05:28
So sorry, but I am unable to log into this page. I even had my pw reset. The login screen keeps poping up.
jbburks Fri, 04/13/2007 - 18:48
On Vista:
- still no personal firewall or firewall check
- no 64-bit support
Cisco continues to have their head in the sand.
I have two recommendations:
- contact your account team and ask for proper Vista support
- select another vendor for VPN if you consider Microsoft Vista as a client
Toivo Mon, 04/23/2007 - 11:02
Version 5.0.00.0340 of the VPN client has a readme with a link to open caveat CSCsi26086 "Upgrading from XP to Vista not supported."
This is pretty much a show stopper; if people who upgrade from an XP install with our mandated antivirus/firewall on it won't be able to get the VPN to work on the Vista box, that affects a significant portion of our client base.
It sounds like there won't be an easy fix for this, but Cisco does need to do /something/ to address the situation, either a list of supported and known faulty legacy software, or some other means of allowing the use of their VPN client on Vista.
