internal cisco vpn clients timeout
Mar 8th, 2007
Hi all,
I have some internal users who are trying to connect to an offsite VPN server using Cisco VPN client. The client will connect but timeout at 1 min 40 sec each time. I have a PIX 525 on my Internet conncection. Is there anything I need to do on my inside or outside interface to assist users who are trying to establish such offiste VPN conenctions? I do have IPSEC enabled on my outside interface for my users remoting in to my network and have a VAC+. Could this have an affect?
Thanks, Steve
kaachary Fri, 03/09/2007 - 02:29
  • Cisco Employee,
Is the PIX running 7.x code ?
If yes, Check the max connection timeout value and idle timeout value in the group .
Also, can you capture the logs from the client, when the disconnection occurs.
-Kanishka
