Want to globally manage all Wireless devices with wired ones using SNMP
wbenton-0
Wired devices are already managed, but wireless devices of particular interest which I desire to manage are:
Autonomous:
AIR-AP1121G-J-K9
AIR-AP1121G-J-K9
AIR-AP1131AG-J-K9
AIR-AP1131AG-P-K9
AIR-AP1131AG-J-K9
AIR-AP1131AG-P-K9
AIR-AP1210
AIR-AP1210
AIR-AP1210
AIR-AP1210
AIR-AP1231G-J-K9
AIR-AP1231G-J-K9
AIR-AP1232AG-J-K9
AIR-AP1232AG-P-K9
AIR-AP1232AG-J-K9
AIR-AP1232AG-P-K9
AIR-AP1242AG-P-K9
AIR-AP1242AG-P-K9
WLC
4400 Series Wireless LAN Controller
2100 Series Wireless LAN Controller
3750 Series Integrated Wireless LAN Controller
Is there any single document which compares which traps/alerts are available in which devices/IOS versions or must I pull teeth to compare them?
A simple reference chart/URL would be quite helpful.
prakashj
Hi wbenton,
Regarding Autonomous access point ,You can add your wired monitor SNMP community config in Autonomous access point.The same will be able monitor globaly
Eg:Cisco works.
I hope this will help you.
Regds
Saji k.s
I know I can add the SNMP community config in them, but what I'm looking for is:
A single document which compares which traps/alerts are available in which wireless devices/IOS versions for each of the above devices or must I pull teeth to get info about each one separately?
Walt
The AIR-AP1121G-J-K9 gives off certain traps. What are they?
Likewise, all of the following devices also give off traps.
AIR-AP1121G-J-K9
AIR-AP1131AG-J-K9
AIR-AP1131AG-P-K9
AIR-AP1131AG-J-K9
AIR-AP1131AG-P-K9
AIR-AP1210
AIR-AP1210
AIR-AP1210
AIR-AP1210
AIR-AP1231G-J-K9
AIR-AP1231G-J-K9
AIR-AP1232AG-J-K9
AIR-AP1232AG-P-K9
AIR-AP1232AG-J-K9
AIR-AP1232AG-P-K9
AIR-AP1242AG-P-K9
AIR-AP1242AG-P-K9
WLC
I'm sure that not all devices list above give off the exact same traps nor do all the devices support the same IOS versions.
That said, looking at which devices support which IOS versions and then looking into each IOS version "ASSUMING" that every device supporting that IOS supports all of those traps is an assumption which network managers cannot take.
So back to my original question.
Where can I find a list of Alerts supported by each of the above listed products?
Walt
