Access to VLAN subnet from WAN
Mar 9th, 2007
hi,
I would like to access to a VLAN subnet from WAN.
In my setup, I have a Cisco 1841 which does the VLAN routing. 2 VLANS are defined: native vlan and vlan 172. All PCs are on native VLAN while VLAN 172 used for Voice equipment.
It has 2 routes:
1st route to ADSL router: ip route 0.0.0.0 0.0.0.0 192.168.1.2
2nd route to a wireless network
ADSL gateway on native VLAN.
I can connect through dyndns to any PC on the native VLAN, but would like to access to a PC on vlan 172 on SSH (port 22).
How do I do the routing on the ADSL gateway to forward any traffic on port 22 to the PC (172.16.0.11) on VLAN 172?
hoogen_82 Fri, 03/09/2007 - 00:41
  • Silver, 250 points or more
Hmm.. i am not yet sure about your network, but i guess PBR could work.
Route-map ssh permit 10
match ip address 101
set ip default next-hop 172.16.0.11
route-map ssh permit 20
access-list 101 permit tcp any any eq 22
I may not have got the syntax correct but this is a skeleton configuration on which you can work.
Identify from where the traffic is coming from and apply ip policy route-map ssh
Cheers
Hoogen
rsabapathee Fri, 03/09/2007 - 05:27
thanks for reply.
But it sounds you are saying to configure this command on the ADSL gateway. The gateway is a non-cisco router, which does not know about the 172.16.0.0 network.
Only the cisco router which does the VLAN routing knows about that network.
Amit Singh Fri, 03/09/2007 - 05:58
  • Cisco Employee,
Please paste the your network diagram and configuration of the router.
-amit singh
