ASA - Cut-through proxy probleme
Mar 9th, 2007
I have to configure my ASA 7.2.2 for cut-through proxy but when the users use authentication prompt ,
but only , for (http://1.1.0.2/netaccess/connstatus.html) the ASA send the following message:
User Authentication
User Authentication is not required.
help me
it is ok when one uses cut-through-proxy by ACL :
access-list ACL_INT extended permit tcp object-group PC-UAUTH_DYN host MVINCT19 eq www
access-list ACL_AUTH line 1 extended permit tcp host poste_auvinet host MVINCT19 eq www
aaa-server auth_inside protocol radius
aaa-server auth_inside host SVR-ACS-IN
key xxx
username admin password xxx privilege 15
aaa authentication match ACL_AUTH inside auth_inside
aaa authentication listener http inside port www
on a pix 525 is OK
Vivek Santuka Fri, 03/09/2007 - 05:13
The config looks good. Please remember that successful authentication is cached (show uauth) and till it expires user will not need to authenticate again.
Please clear uauth and see if it helps.
Vivek
a.auvinet Fri, 03/09/2007 - 06:40
after "show uauth"
it no user to connect there, and always the same message!!
