LAN2LAN between ASA and Cisco 2821
Mar 9th, 2007
Greetings,
Users on remote network behind Cisco 2821 reporting dropped connections to mail server behind ASA. 20-seconds later, the connections get re-established. I run a constant "ping" to the remote LAN and do not see a drop over the tunnel.
Any ideas?
Thanks.
kaachary Fri, 03/09/2007 - 07:29
  • Cisco Employee,
Try enabling "inspect esmtp" to see if that helps.
-Kanishka
iholdings Fri, 03/09/2007 - 10:25
Thanks for the quick reply.
As I understand what I've read - esmtp inspect is on by default on the ASA. Is that true? So - in this case - would I turn it on in the router as well? BTW: These two sites are on a LAN2LAN VPN .... does that change what you suggested?
Thanks.
Kamal Malhotra Fri, 03/09/2007 - 15:24
  • Cisco Employee,
If you are running 7.2.2, try disabling the inspect esmtp on the ASA rather than enabling on the router.
HTH,
Please rate if helps,
Kamal
