CCM help
Answered Question
Mar 9th, 2007
hi,
where i work a phone extension was configured in the past to have external calls from a direct outside line forwarded to it. How do i remove these configurations to stop this from happening?
Correct Answer by mchandak about 10 years 4 months ago
If you know what the external number was being received by CM, then you can use Route Plan Report (CCMAdmin Page ---> Route Plan ---> Route Plan Report) to find the number and delete it.
Overall Rating: 5 (1 ratings)
Correct Answer
mchandak Fri, 03/09/2007 - 06:08
  • Gold, 750 points or more
