Inter VLAN routing on Catalyst 3750
Mar 9th, 2007
I am new to Vlans so any help is greatly appreciated. I am wondering how I can route between two vlans on the same switch. I created a vlan (500) and assigned two ports to it. The vlan 500 ip address is 10.0.101.2/24. The vlan 1 ip address is 192.168.0.30/24. When I am consoled into the switch I can't ping the vlan 500 interface. So I obviously I can't ping the 10.0.101.2 interface from the 192.168.0.0/24 subnet. I plugged a computer directly into the switch and was able to ping the vlan1 interface(192.168.0.30). I also added a route to the computer to go 192.168.0.30 if it wants to get the 10.0.101.0 network. I've tried to add routes on the switch to each subnet but it didn't seem to work.
Here is what my config looks like.
interface GigabitEthernet1/0/1
switchport access vlan 500
switchport mode access
interface GigabitEthernet1/0/2
interface Vlan1
ip address 192.168.0.30 255.255.255.0
interface Vlan500
ip address 10.0.101.2 255.255.255.0
I was doing research and was finding different things about trunking, but is that really necessary when the two vlans are on the same switch?
Thanks in advance to any help.
Overall Rating: 5 (1 ratings)
Danilo Dy Fri, 03/09/2007 - 06:39
  • Blue, 1500 points or more
Your configuration looks okay. However, have you enabled routing? Is your IOS EMI model? Execute "ip routing" in configuration mode.
Download this Cisco Catalyst 3750 configuration guide book for 12.2(35)SE http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_book09186a0080763466.html
Here's all the configuration guide for different IOS feature set, pick your IOS trail (SE, SEE, SED, ...) http://www.cisco.com/en/US/products/hw/switches/ps5023/products_installation_and_configuration_guides_list.html
It has everything from stacking, configuring VLAN, STP, QoS, HSRP, Troubleshooting, IPv6, etc...
Robeast29 Fri, 03/09/2007 - 07:03
Thanks for the help. Yes I do have IP routing enabled. Here is something from the config file..
no aaa new-model
switch 1 provision ws-c3750g-24ts
ip subnet-zero
ip routing
Thanks again.
acomiskey Fri, 03/09/2007 - 08:06
  • Green, 3000 points or more
You dont need to add routes to the switch as they are directly connected.
Danilo Dy Fri, 03/09/2007 - 08:33
don't forget "ip classless" as well and make sure vlan interfaces is up by executing "no shut" in the vlan interface config mode, vlan interfaces are shutdown by default :)
Kwakachunga Fri, 03/09/2007 - 08:02
Confirm if int vlan 500 is up(sh int vlan 500),if not do a no shut on the interface,then plug ur machine on to interface GigabitEthernet1/0/1(a member of vlan 500) ,give it an ip like 10.0.101.2 /24 then give it a default gateway of 10.0.101.2/24....then get back to me
Amit Singh Fri, 03/09/2007 - 08:33
  • Cisco Employee,
Please paste the output of " show vlan " and " "show interface vlan 500".
-amit singh
glen.grant Fri, 03/09/2007 - 09:53
  • Purple, 4500 points or more
Verify you created your layer 2 vlans "show vlan" or "show int status" and the ports show assigned to the vlans you want them in .
Yes you need a router to route between VLANs.
Router work on Layer 3 of the OSI Model.
Switches work on Layer 2 of the OSI Model.
VLANs seperate broadcast domains (subnets).
You have two options on the router.
1. You can use two ports on the router, one for each subnet.
2. Setup trunking on one of the routers subinterfaces (physical interfaces broken nto into multiple logical interfaces).
cratejockey Sun, 03/11/2007 - 23:05
Things are getting a bit muddy here. The switch that is referenced in the original post is a 3570. The 3570 is an L3 switch meaning it is capable of doing both L2 Switching and L3 Routing (essential and Ethernet router). The 3570 with baseIPServices should support IP routing with STATIC ROUTES and EIRGP-STUB Routing (Receive ONLY updates). If you are using IP Advanced Services image then the unit will support quite a bit more.
We use a lot of these type of L3 switches to accomplish your overall goal which is to route between multiple VLANs.
The basics are as follows;
1. Create your VLANs; Do this using the VLAN database command or VLAN commands from global config mode
2. Assign IP addresses (gateway address's) for each of your networks to their VLAN Interface in interface config moe (ie. interface vlan 100). This give your devices default gateway's through which they can communicate with other devices through routing.
3. do a no shut on each vlan
4. If your just using this one switch assign VLAN's to ports on it. If your using other switches configure your Trunks (Thats another discussion) then make sure you have active clients on the vlans.
5. Enable routing in global config mode.
6. do a "sh ip route" to ensure that your 3570 is seeing the connected networks.
Lots more could go into this but these is the basics. If you go to this link
http://www.staticnat.com/WP/configs/3550/3550-48-emi-vlan/
You will find a sample config of this from a 3550 running EMI. This config is running EIGRP as well as Multicast routing. There are a total of 16 VLANs plus VLAN 1 which is disabled. You will still need to create the vlans in VLAN Database or config mode but overall this should help clear things up.
Good luck.
