OSPF routing issue
Mar 9th, 2007
We have siteA and SiteB, siteB acting as a redundant data
ceter. We have MPLS connection to our remote sites from both location.We also have a dedicated DS3 connection from SiteA and SiteB to our West coast site. In order to do a failover, I shut down MPLS from Site A and desired Site A to learn routes via siteB, but this didn't happen. SiteA actualy started learning routes via west coast location which brought my utilization upto 90%.
I remember in RIB you can specify an offset-list 0 but what can be done in OSPF, please advice.
Thans.
rais Fri, 03/09/2007 - 06:57
If MPLS is down at A, the only connection that remains there is ds3. This means A connects to B via West Coast now. Isn't this behavior normal then? Did I miss anything?
Thanks.
nawas Fri, 03/09/2007 - 07:05
I think I missed some information.
westcoastDS3 and ATTMPLS on siteA WAN router which connects to siteA core and site A core connects to siteB core via dark fiber and siteB core connects to siteBWAN-- where I have ATT MPLS connection and Westcoast DS3. Hope this helps. In this case. All the core routers are Cisco 6500 with SUP720s and wan rotuers are 6500 with sup1a.
rais Fri, 03/09/2007 - 13:31
In that case, I believe you have ospf adjacency on the fiber link as well. You may have to adjust bandwidth/ospf-cost on your ds3 or fiber link so that cost is lower on fiber link.
Hope this helps.
