Problems with config synchronisation on failover unit
Mar 9th, 2007
Hi - I've recently swapped a PIX 515 with a failover licence for a replacement unit and since then can't get it to synchronise it's config. The licence says "This platform has a Failover Only-Active/Standby (FO) license"
and the message I get in the logs is;
Message #545 : Detected an Active mate
Message #546 : Unable to sync configuration from Active
Message #547 :
Message #548 :
Message #549 : ========================= NOTICE =========================
Message #550 : This platform is licensed to run in
Message #551 : failover secondary mode only
Message #552 : ==========================================================
It's running version 7.2(1) code - Any ideas? Can't find that message anywhere on CCO or google.
Thanks in advance
vitripat Fri, 03/09/2007 - 10:49
What version is running on the Primary-Active PIX? If the versions are same, did you execute following command on the Secondary-Standby PIX:
failover
Let me know if this helps.
Vibhor.
d-fillmore Mon, 03/12/2007 - 07:52
Hi Vibhor - Thanks for your reply, The other PIX is running the same code and has an unrestricted lisence.
The active unit is in a live environment. What do you think that command will achieve?
Thanks, Dom
d-fillmore Tue, 03/13/2007 - 08:12
Thanks Vibhor - There is a line in the config thats says failover, and the output of 'show failover' shows that failover is on.
Something else I've noticed is that the interfaces on the FO unit all say interface down, line protocol up;
Interface config status is active
Interface state is not active
and they all show as waiting in the 'show failover' output;
This host: Secondary - Sync Config
Active time: 0 (sec)
Interface outside (0.0.0.0): No Link (Waiting)
Interface inside (0.0.0.0): No Link (Waiting)
Interface dmz (0.0.0.0): No Link (Waiting)
I'm going to verify that the interfaces are actually plugged into a switch! Do you know if this would affect the ability of the device to sync it's config?
Cheers, Dom
