IPMA Failure on both Assistant and Manager
Mar 9th, 2007
CM 4.1(3). I used the wizard to configure one manager and one assistant. I changed the templates on the phones and changed the softkey templates. I then subscribed each phone to the service.
On both phones, when I use the services button to "use" the service, I get the following error message "A system failure was found. Please contact your system administrator"
jeffrey.girard Fri, 03/09/2007 - 09:35
Brandon -
Thanks for you reply, but no good. I restarted the app as you suggested with no changes. I have also restrated TomCat several times with no changes.
Brandon Buffin Fri, 03/09/2007 - 10:39
Does the Control Center show IPMA as Activated? Also, check the URL in the IP phone service. It should be:
This URL is case sensitive, so check captitalization as well.
jeffrey.girard Fri, 03/09/2007 - 10:54
Brandon -
Yes, on the control center activation. I have opened up a TAC case (Im on the phone with him now as I type this). I assumed that the wizard would make all the ncessary config changes for me. Nope. It does not set any of the service parameters. After I set the parameters and restarted Tomcat, my manager phone is now working, but my assistant is not. The error message that comes up when I request the service is "IPMA is not supported on this device". Its a 7960 and yes - the assistant is already associated to the route point and to the phone used for IPMA
Tim Smith Tue, 01/08/2008 - 09:07
Hi Jeffrey,
Only the manager needs the IPMA service on the phone.
The assistant should be using the IPMA assistant application to interact with IPMA.
