CCMUser login failure
Mar 9th, 2007
Users are unable to access CCMUser/login.asp page. Authentication window comes up, but after user/pass are entered, they all get below error. This worked in the past. Any ideas.
Microsoft JScript runtime (0x800A138F)
'undefined' is null or not an object
/CCMUser/_top.asp, line 77
jbarcena Fri, 03/09/2007 - 10:31
  • Red, 2250 points or more
What is the exact CCM version that you are running?
Please check the following:
On the server go to: Start>Programs>Admin tools>Interner Services Manager> Expand on the server's name and look for the CCMUser, right click on it and select Properties. Go to the Directory Security tab and click on the first "Edit" Make sure it is set to Anonymous access, then click on the "edit" button and double check that it has the CCMUSER selected.
Try resetting the password for the CCMUser account in Local Users/Groups and in Internet
Services Manager for the ccmuser virtual directory
Then restart the IIS service and then give it a try.
Also make sure to have the following settings:
The default settings for IIS:
IIS for
Server: right click properties --> Master properties --> Edit --> Directory
Security
Anonymous Access checked -->Edit --> IUSR_guest
Integrated Windows Authentication checked
Default Web site -->
Directory Security
CCMUser -->
Directory Security
Anonymous Access checked -->Edit --> CCMuser
In CCMuser what is the Virtual Directory for CCMuser
Should be:
C:\CiscoWebs\User
Application protection : HIGH
Under Administrative Tools --> Component services My PC --> IIS (Default web site//root/ccmuser) Is created
