Antonio Brandao Mon, 03/12/2007 - 05:36
Thanks, its work now.
but i still have a problem :
The machine is plugged to switch trough two nic interfaces, when i disconnect one of two links, the the channel continue working, and when i back to plug the disconnected link , the machine stops to respond ping.
what can be occuring ?
Thanks , Antonio
Jon Marshall Mon, 03/12/2007 - 08:54
Hi Antonio
Does the machine stop responding to ping for good or does it drop packets for a bit but then the ping continues ?
If the latter it looks like it could be a spanning-tree issue.
Jon
Antonio Brandao Mon, 03/12/2007 - 10:45
Jon,
The interface stops to respond ping -t command..and to come back work again, i have to remove and to create the port channel interface on switch.
follow attached , the switch configuration.
Att
Antonio
Jon Marshall Tue, 03/13/2007 - 01:02
Antonio
What is the status of the remaining port when you reenable the other port ?
Jon
Antonio Brandao Tue, 03/13/2007 - 05:18
Jon,
It?s working now,
I think the problem was in vmware esx 3.
After i had make some alters in some flags in network features, the system is working.
If i remove one of two interfaces and and i re-plug that, the system continues ping.
Thanks Jon.
mlebus Fri, 04/06/2007 - 18:08
Antonio,
Curious to know what changes you made in ESX.
We've seen the same problem and not found a satisfactory solution.
