NM module for the 2610?
Mar 9th, 2007
I need to purchase a module with FXO ports for my 2610 router. The Cisco website doesn't seem to have card compatibility information because this router has reached end-of-life. Can someone tell me which model I should loo for? Just looking for a module that I can plug an anolog line into so that CallManager can send calls to and recieve calls on (MGCP).
-Shikamaru
mchandak Fri, 03/09/2007 - 10:13
I dont think you would be able to get any part which would work on this. The right part on a 26xx Router for MGCP would be to use a NM-1V, NM-2V with VIC-2FXO card.
