ASA5510 Unable to remove peerTblEntry
Mar 9th, 2007
I'm not able to connect a Windows XP VPN Client with my ASA 5510 over a L2tp/IPSec vpn connection. I'm using the ASDM management console with the internal Remote Access Wizard. When a user is trying to connect to the ASA I receive this in my logs:
4 Mar 09 2007 14:42:15 713903 IP = *.*.*.*, Error: Unable to remove PeerTblEntry
3 Mar 09 2007 14:42:15 713902 IP = *.*.*.*, Removing peer from peer table failed, no match!
3 Mar 09 2007 14:42:15 713048 IP = *.*.*.*, Error processing payload: Payload ID: 1
Those someone can give me a hint o how to solve this problem?
ggilbert Fri, 03/09/2007 - 12:34
  • Cisco Employee,
Its a general error message stating that its not able to create a SA table entry for the remote peer.
deb cry isa 129
deb cry ipsec 129
Run those two debugs and post them. Let see where the problem is.
Thanks.
Gilbert
