Rajat Chauhan Fri, 03/09/2007 - 21:54
1. The DLCI number defines a single virtual connection through the WAN and are the Frame Relay equivalent to a hardware address.
Periodically, through the exchange of signaling messages, a network may announce a new virtual circuit with its corresponding DLCI number. However, protocol addressing is not included in the announcement. The station receiving such an indication will learn of the new connection, but will not be able to address the other side. Without a new configuration or mechanism for discovering the protocol address of the other side, this new virtual circuit is unusable.
For this reason, Inverse Address Resolution Protocol (Inverse ARP) was developed. Inverse ARP allows a Frame Relay network to discover the protocol address associated with the virtual circuit.
Inverse ARP is used instead of the "frame-relay map" command which allows you to define the mappings between a specific protocol and address and a specific DLCI. Usually you would only select Inverse ARP if you want to configure an interface for multipoint communication. You would not need to select Inverse ARP if you have a point-to-point interface because there is only a single destination and discovery is not required.
2. If you do not have the IP address space to use many subinterfaces, you can use IP unnumbered on each subinterface. You need to use static routes or dynamic routing for your traffic to get routed. And you must use point-to-point subinterfaces. For more information, refer to:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a0080087d01.html#1003234
Please rate as needful.
Rajat Chauhan
carl_townshend Mon, 03/12/2007 - 13:01
so would we do a show frame relay map, and then point a route to the ip address that its showing as the other end ?
Rajat Chauhan Tue, 03/13/2007 - 20:47
show frame map will not show any ip-address,it'll only specify dlci mapping and link state (point to point or multipoint).
Do not confuse frame-relay with routing, its just a L2 setup like ethernet, and once done, you can configure routing like you always do.
Hope it helps.
Please rate as applicable.
Rajat Chauhan
