Adding static route on the sensor
Mar 9th, 2007
I have done some research looking around the forum, docs and could not find any details whether a static route could be added onto 4215 sensor besides the default gateway.
Is that feature not supported? Has anyone ran into similar issue?
vitripat Fri, 03/09/2007 - 12:41
We cant add routes on the IDS devices. Its not supported. IDS is not supposed to route any traffic, it can only send the traffic to the gateway assigned. :-(
Hope that helps.
Vibhor.
mhellman Fri, 03/09/2007 - 15:03
I'm not sure what you mean by that. Adding a static route doesn't mean the IDS is suddenly acting like a router and it doesn't have security implications.
Does the IDS accept ICMP redirects?
