AnyVPN - 64-bit Vista - ASA vs. Concentratorsq
Mar 9th, 2007
Does anyone know if the new AnyVPN client for 64-bit Vista will connect to IPSec enabled 3xxx series concentrators or only to the newer ASA's?
ggilbert Mon, 03/12/2007 - 07:46
The Any connect VPN client will not connect to the 3000 concentrators - Only to the ASA's
Rate this post, if it helps.
cassmith Mon, 03/12/2007 - 16:19
Where can you get this "Any connect VPN" client? Is this different then the standard "Cisco VPN Client" for IPSec?
Any helpful solution allowing my Vista 32Bit Upgrade clients and Vista64Bit clients to connect to our PIX 6.3(5) or ASA Firewalls would be appreciated.
ggilbert Mon, 03/12/2007 - 18:31
The "Any connect VPN" client is still in ASA Beta testing. You have to enroll into the Beta testing process to get this client.
The "any connect VPN" is different from the Cisco IPSec VPN client.
To get this Beta software, please contact your Account team and they will be able to help you out.
Also, the Vista IPSec client are in beta testing as well.
Phillip Remaker Fri, 02/19/2010 - 11:37
For IPSEC connectivity, you need the VPN client.  A 64 bit version is now in beta:
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: (under 5.BETA)
Software is available for download by any customer with a SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
