AToM on a 3600 - ?
Mar 9th, 2007
Hi:
Do any of the 3600's support AToM for MPLS?
I am able to use L2TPv3 on a 3640 running c3640-jk9o3s-mz.124-7a.bin.
Here is what I get:
R6(config-if)#xconnect 1.2.3.4 1 encapsulation mpls
% Invalid input detected at '^' marker.
R6(config-if)#xconnect 1.2.3.4 1 encapsulation ?
l2tpv3 Use L2TPv3 encapsulation
Thanks for your help.
Best Regards.
mheusinger Mon, 03/12/2007 - 09:54
the clear answer is: NO.
You need f.e. a 7200 series, or the c7200 router simulator to configure this.
Regards, Martin
rajju Fri, 03/16/2007 - 10:38
Thank you for your reply.
Interestingly, I can run L2TPv3 with no problems, either using a Lan or a Wan interface. (maybe becoz' it is a Cisco-proprietary solution) ;->
Best Regards.
